Please help me out to get rid of "stripes" that show up on display when taking pictues. I have DSC-S730.
Hi
Unfortunately I would guess that both cameras are faulty; sorry. If you use the below link it will direct you to our service website. Enter you model number into the search box and it will direct you to the correct service process.
http://support.sony-europe.com/repair/index.aspx?site=odw_en_GB
Regards
Lee
I'm trying to get info on horizontal stripes on my DSC-S980, so I will be very interested to see any reply you get.
I bought mine in May 2009, so its out of guarantee.
My problem only started last week and happens on every photo.
Message was edited by: franksmyth
Hi
Regards
Lee
