Hi, i recently bought a SONY DSC-WX9. It seems to be ok apart from one thing. While am watching the videos i've shooted i see something like pixeling on the horizontal level. Am not moving the camera too fast while recording and ive never seen something similar or a problem like mine mentioned on the internet so far.
This happens either in FX or simple HQ recording.
Thank you for your help
Message was edited by: eftihas
Hi Mick,
I think i found the answer...My graphics card resolution 1600x900..Shall i continue? Nope!
Obviously it cannot produce a resolution of 1920x1080.
Had my mind on my older lap top which was full HD coz it could play Blue Rays and didnt search for the minimum requirements for this kind of resolution.
Thx a lot for your help. Lots appreciated,
Eftihas
By sheer coincidence, a videographer friend of mine told me he'd just traded up his MacBook Pro due to display issues. He mentioned his old one had an NVIDIA graphics card and when I checked, it was the exact same one as your Viao has! A common issue with laptops, it seems.
Glad you got to the root of the issue – good luck with everything.
Mick
