I have recently purchased this camera. Is there a macro available to enable very close up shots?
Hi @Buckingham18,
well, the DSC-WX350 has got a fixed lens so that you cannot remove it and replace it by a different lens like a macro lens.
darkframe
Use the Intelligent Auto selection and get in close. This usually triggers the Macro function. I don't get it to work consistently, so I'll get back to you if I get something figured out.
