Hi. I was led to believe that it was possible to get a still image from video with this camera. However, the function for doing so seems to be disabled on my camera. Is this a fault or is it not possible on the M2 ? Thanks in advance.
Hello @TweakyBlinders,
you can always pull still images from the videos via VLC or any video editing software.
I think the function you are referring to is the one where you put the RX0m2 on top of a photo camera and use it for video/photo while the "big" camera beneath does the opposite.
- Nic
