When I click "send to computer" in the menu on
my DSC-HX60v I get the following message;
Information of the computer where the data is to be saved is not set to the device. Connect the computer to the device with a USB cable and set it.
Any ideas on how to set it please?
Regards,
harwoodlad
You have to install PlayMemories Home first and then register the access point in the camera.
See also: https://helpguide.sony.net/gbmig/45299231/v1/en/contents/TP0000518267.html
Many thanks Peter - I'll give it a go later today.
Phil
(harwoodlad)
Good luck with that, very few actually manage to get it working. You could also try Imaging Edge if that doesn't work.
