Hi, its my first time on forum & discussions, so can you please help me, i have just got hold of a cyber cam dsc-h5 ( silver) can not find software application for this product. can some one please advise how to do it . many thanks.
If you go to the Support Page for your camera, you will find replacement software.
http://support.sony-europe.com/dime/digistill/cyber/cyber.aspx?site=odw_en_GB&m=DSC-H5
There are also helpful tutorials to help you get the most out of your camera.
