- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Good afternoon D
Please cancel the above post
I was quoting the battery number from the wrong camera.
The battery from Duracell Direct works fine. Just got to find instruction book to charge the battery
i am too old!!!
You can order with confidence from Duracell Direct (£16.99) in UK
Regards
Derek
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Hi. I had the same problem, I suspect your original battery is the "info lithiam" version. I believe sony sells them for around £80 Regards D
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks D for your reply.
I am online trying to find the battery on the Sony website- failed completely. No list of batteries
The £80 Sony battery what was the approx date for this?
MY existing Sony battery is a NP-FR1 which Duracell Direct said was obsolete. The battery that Duracell supplied
had 4 contacts instead of the 3 on the existing battery. I rejected this battery on visual inspection only.
Regards
Derek
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Good afternoon D
i am too old!!!
Regards
Derek
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi. I'm away from home at the moment so can't check the battery number, but I know the battery from my modern Alpha A65 fits my 22 year old sony DSC-S70 . I tried a Duracell it didn't work because it wasn't "info lithiam" have a look at the Sony Alpha a65 battery images. (The Duracel worked in the Alpha a65)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No worries Derek. Glad you found the solution. I think the battery charges in the camera.
Regards David
