Hi Guys,
I have formatted the internal memory by mistake and recorded few videos. Can I recover the old videos (before formatting)?
Thank you!
Hi @wahbi1,
I am not familiar with that particular camera - does it use some sort of flash media (SD card or similar) which you can access via your computer and a card reader?
If so, I personally would go with testDisk by CG-Security which I used successfully to recover videos in the past.
While it has no graphical user interface, it works pretty well. Make sure to use the documentation on the developers website AND consider leaving a donation if you can successfully recover the files you erased.
- Nic
And be patient when you're using the software.
It takes lots and lots of time, but it does recover pretty well.
Thank you very much Nic. Much appreciated!
Thank you Strangle!
