Hi All, I have a slightly similar question relating to LCD icons. I have two cx450's and a cx240 connected to an ATEM mini. One of the three cameras still shows the STBY and MENU icons (along with W and T) in the computer screen. Depending which camera is plugged in last, it is always the last connected camcorder that shows this on the computer screen (they all show on LCD).
All are on the "AUTO" setting in display settings. All LCD's do the 3 second disappearing thing but the third camera the STBY etc reappears on the computer screen after the 3 second rule.
Any help to remove these from the computer screen will be grateful. The problem will move from camera to camera depending on which one is connected last, so I presume this might be something in the ATEM software???
many thanks Gary
hard to tell. Have you contacted ATEM and asked them if this is a known issue?
Thanks Peter,
yes I have contacted Blackmagic and am awaiting their reply.
