Hi there,
I have an old Handycam DCR-SR37. It's from 2009 and has never had any update (if available). I wish to use it to live stream. Is it possible? If so, how do I do this?
I have searched thought the internet and the only things I can find are for the DCR-SR37E. Mine doesn't have the functions described in those posts.
Are there any updates available for this old girl? where can I find them, if available?
Many thanks,
Borealis999
Hi @borealis999
What's your user case?
If it is to revive your 'old lady' then go here or Google.
Don't forget Youtube, it's surprising how many inventers share their findings over there.
If it's just the streaming then buy a cheap plug-and-play in your local shop.
I believe the DCR-SR37E is the European model (hence the E), but I couldn't find the one without an E except for a singular Amazon listing for a cable.
Hope this helps somehow!
- JD
