- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
April 2011
April 2011
When filming with my Dvd203e, I have sound but no picture. I cannot take photos either. I would appreciate any help.
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2011
May 2011
Problem solved....there was dust on the lens so the shutter could not open,
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2011
April 2011
Sounds like there could be a problem there. A few questions for you.
- If you use the viewfinder, is there any image?
- Do menu's appear on screen or is that dead?
Looking at it, I cannot see any specific settings which you might be able to access. There might be a small reset button after you open the LCD screen which you might want to try.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2011
