- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
DCR-HC30E
Hi All,
My other half and his dad bought a DCR-HC30E a good few years ago. Since owning it nobody has eve found out how to download the videos? Oh and they have lost the Memory Stick, still have the USB Cable to connect it to the laptop.
I have two questions What is a reasonably priced software that will work with this camera as I've tried to download the drivers and nothing is working.
Secondly to I need the memory stick to transfer from the Tape??
HELP all I want to do is download some treasured memories!
Any help grateful.
Suziebear
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Suziebear
Depending on the PC you have, there is a good chance it will have Windows Movie Maker installed which is a perfectly reasonable editing tool.
The video from his camera can only be transferred to the PC via the i-link socket and matching cable. Assuming you have the same connection on your laptop it should be a simple matter of buying an i-link cable. These are available everywhere. I have provided the link below to give you an idea but you don’t have to buy a Sony cable.
http://www.sony.co.uk/product/cac-cables---connectors/vmc-il4415
With i-link the required drivers should already be installed in the operating system so all you should have to do (once its all plugged in) is turn the Handycam into play mode and open WMM.
Hope this helps.
Lee
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
THANK you so much I have a cable on order will post once I have tried it out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi All, So none of you make the same mistake as me. I order a 4 pin to USB and a 4 pin to 6 pin. Both are these are wrong..... should be 4 pin to 4 pin read article I just found else where...
Hi There
I had similar problem with my Sony Digital8 (also called HI8 ) handycam. My vista system was not able to detect my Handycam with a very very cheap FIREWIRE PCI Card I bought in local market for only $4, yes four dollars. It came with 6pin to 4pin Firewire cable(Sony calls it i.Link). I was trying to connect with same cable 4pin at camera end and 6pin on PCI Card, with no luck. It was even showing DV-IN on camera LCD with this 6pin to 4pin cable. I tried everything an expert would do, but got only frustration. Even tried a lot on Internet for the solution but it seems no one knew.
Then I started from scratch, TO DECIDED TO READ MANUAL. While reading the PDF manual found on Sony Support site, trust me, I found those golden words "USE ONLY 4PIN TO 4PIN i.Link Cable for Firewire connection."
I ran back to market and bought 4PIN TO 4PIN Firewire Cable for $1.5
At first trial, trust me, it detected "SONY DV Camcorder" and installed drivers automatically. I confirmed by going into Device Manager and found same entry in Imaging Device section. Then what in every possible software existed on my system, DV Capture was available, which was found always disabled.
Now the funny part it, technically there is no difference in 6pin to 4pin Firewire cable as two pins are used for Voltage which is discarded at 4 pin end. But it seems SONY Handycam does not wants itself to connect it to 6pin socket at PCI card end.
So these are the final things to remember.
1) Use only 4pin to 4pin Firewire cable (any cheaper make. $1.5 will do)
2) Use any cheaper FIREWIRE PCI card with at least one 4pin firewire socket. When installed XP or Vista will install driver automatically just confirm that "IEEE 1394 bus host controller" entry is shown in Device manager or not.
3) No matter you use cheaper or costlier PCI card or cable the quality will always be same coz D8 Handycams directly transfer encoded Video Data in Digital format thru Firewire cable. Firewire cable does not transfer RF video input. I get default video with 720x576 with 25 Frames/s in PAL mode.
4) No additional codecs are required to install in pc like others suggested. Required codecs are always there in XP and VISTA with windows movie maker.
5) No additional software is required, as you can directly capture with Windows Movie Maker in high quality. My choice is Adobe Premier CS3. If you want to make directly MPG file you may use ULEAD VIDEOSTUDIO 8 or later.
6) Do not blame SONY as they already told you which exact cable to use.
7) Do not blame Vista. Its nothing to do with it. Sony's PicturePackage for XP does not work on vista. For vista they offered PICTURE MOTION BROWSER which also have easy VIDEO Capture utlity with same high quality capture. Some people falsely claim that "VISTA DOES NOT WORK WELL WITH FIREWIRE" That is completely wrong. See, one or few people may have problem and they always keep shouting for thier fate. But it actually it could be thier local hardware or software problem or anything. There could be many reasons at the same time too. Many people even do not care to change to new cable and keep trying on same thing. Actually cables are very delicate rubber material. Many a times you get faulty cable in new petty pack box of devices. Or it could be some firewire chipset problem too. Last is driver problem. Many firewire card manufacturers have not yet made stable drivers for vista. Most problems are solved if newest drivers are downloaded and installed.
7) In handycam mode, you can control PLAY/STOP/PAUSE of Handycam from PC itself from all the video software you use, which is high convinience for capturing.
😎 My sureshot capture sequence is as follows.....
a) Remove BATTERY from camera and switch on with AC Adaptor
b) Put it on PLAY/EDIT mode (also called VCR mode).
c) Connect 4pin to 4pin firewire cable on camera side and in firewire PCI Card. Now you see the words DV-IN on LCD of camera, if LCD is open.
d) Now start any Video Capture Software of your choice. You will find CAPTURE command in FILE menu in almost all softwares.
e) Enjoy.....
Trust me I am going to add this information in almost all forums where similar problems were asked but nowhere the solution found. May be I can help them. Trust me I signed up this forum only to add this information.
Thanks for listening
Mahendra
Mumbai, India
