Hi team,
Where do I find the link to make my camcorder compatable with windows 7
Hello edneilly - welcome to the Sony Forums.
For your camcorder, it has been tested by Sony and appears to be compatible with Windows 7 as long as it is a version of Windows 7 that has been pre-installed on your machine i.e. at the factory. If it is a version that you have installed yourself, it may not work.
Full information for your camcorder and Windows 7 is available on this link:
http://support.sony-europe.com/dime/compatibility/cam/win7/cam_win7.aspx?site=odw_en_GB&m=DCR-TRV22E
Looking at the testing table, Windows Movie Maker works correctly in Windows 7 with the DCR-TRV22E so I would advise trying the camcorder with this software first. If you do not already have Movie Maker, it is a free download using the Windows Live service which can be found here:
http://explore.live.com/windows-live-movie-maker?os=other
Thanks
Simon
Message was edited by: blaireau_photo
