Hi I only have Macs in the house and was looking at buying a Bloggie MHS-TS20K, and was wondering how you format your 360 film from that fisheye format to a watchable format with out PMB cause it dont run on a mac, ? ? ? ? ? ? ? ? ? ? ?
so how do mac users do it ?
Hello martinfryer927 - welcome to the Sony Forums.
On your Mac, do you have iMovie installed and if you do, have you tried using that with your video clips?
Other than that, the official software support page for this model does have a Mac equivalent that may be of use to you and it is located here:
Hope this helps,
Simon
Hope this helps,
Simon
