Any help would be appreciated.
It looks like although video transfer from camera to PC is supported by both USB and iLink using Vista and Windows Movie Maker, video streaming is not supported.
http://support.sony-europe.com/hotnews/vista/vista.aspx?site=odw_en_GB&sc=DV
U can use Windows Movie Maker via I link cable which protocol is IEEE1394. On program you go to function chaptering from video device, which is first left in program. On camera set option play-edit.
http://explore.live.com/windows-live-movie-maker?os=winxp
There is free download on internet, if You use Windows 7
There are 4-4 and 4-6 pins I link cable. Sony cameras are always 4 pin, but see DV IN in Yor PC. If You do not have DV IN, there are cheap USB - I Link adapters.
Deinstall K-lite and free codec packs.
Regards
Damac
