Can anyone tell me where I can get a copy of the cd rom that comes in the box with the camcorder? I have just come back from my holidays and want to put my video's on my computer. Hopefully someone out there can help me.
The original software will only work with Windows XP. If you are using Vista or Windows 7, see what is available from here: -
http://support.sony-europe.com/dime/camcorders/sd/dv/dv.aspx?site=odw_en_GB&m=DCR-HC24E
U can use Windows Movie Maker via I link cable which protocol is IEEE1394. On program you go to function chaptering from video device, which is first left in program. On camera set option play-edit.
http://explore.live.com/windows-live-movie-maker?os=winxp
There is free download on internet, if You use Windows 7
There are 4-4 and 4-6 pins I link cable. Sony cameras are always 4 pin, but see DV IN in Yor PC. If You do not have DV IN, there are cheap USB - I Link adapters.
Deinstall K-lite and free codec packs.
Regards
Damac
