Подскажите как снять графический ключ на сони c4.если нет доступа к компьютеру.есть другой способ?
Tell me how to remove a pattern key on sony c4.if there is no access to a computer. Is there another way?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
take a look at this guide
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/m-p/927295#M20
