Most Of The PUBG Players Who Have Sony C3 Have A Problem... After The Game Starts It Says : Your Device Is Not Supported At The Moment But It Will Be Included Later...
IF IT IS A PHONE PROBLEM PLEASE FIX THIS....
Thanks
You need at least 2GB ram in order for the game to work, your phone has 1GB RAM unfortunately.
I found the system requirements for PUBG
At my place no longer sell this line
Unfortunately
@Gamer1402 wrote:Most Of The PUBG Players Who Have Sony C3 Have A Problem... After The Game Starts It Says : Your Device Is Not Supported At The Moment But It Will Be Included Later...
Thanks
I think 1 Gb is Enough for iOS device while Android device like Xperia need 4 GB of Ram To run Pubg.Instead of ruining your mobile device, just try Pubg on PC with emulator.
