hi all,
i was comparing my xperia c camera with other models like t2 ultra and t3 in a shop. then there was xperia c phone with which i compared my phone's camera and i was shocked to see the result. it was giving more clear picture in low light. then i checked its software version again i was shocked after seeing the version. it was 16.0.B.2.21.....!!!! never heard that version before. my phone's software version is 16.0.B.2.16. anyone got update to 16.0.B.2.21??
Is your phone locked to a carrier/network branded?
no its not locked to any network/ carrier.
You can manually flash another country's firmware however to answer your question - Before generic handsets get the update the networks have to all authorise the update, I'm not saying they have to release the update but they do have to authorise it - Then Sony will be authorised to release it to generic devices
thank you
Anytime:)
I don't have this phone to test it myself BUT you can use the search bar (top right corner) and look up for feedback or issues on that update
