Hi All,
How can I enable developer mode in Sony Xperia C??
Can anybody help me??
Thnaks in advance.
Regards
Dear Sir,
I have rooted my Xperia c. Then flashed it to change the S1 Boot version. After that done with the recovery image using Mobileuncle tools, Later i downloaded the Xperia Z-Zied ROM and pasted it in my Sd card but by mistake i misplaced it and aftr going to recovery mode i wiped all the data and system then i went to restore the XperiaZ-Zied ROM but it said the ROm isnt present there i wasnt getting any option about what to and all so I removed the SD card and Transferred The required ROM file to the Required Folder Later when I resumed the recovery section it didnt recognised the SD card. then later when i tried doing Reboot my Xperia is showing the Sony Logo and the Xperia Z-Zied Logo Again and angain in loop. Please sir Guide me with this What should I do..
Thank You
