Hi All,
How can I enable developer mode in Sony Xperia C??
Can anybody help me??
Thnaks in advance.
Regards
Settings > about phone > tap 3 or 4 times fast on build number
Thanks...
How to disable developer mode and what is debug app
To disable developer mode,go to settings-apps-all,find the settings app and clear data.
Developer mode is supposed to be used by developers to improve,test or check some of the phone's functions.If you use them,you need to be careful.Well,from 4 GB you have the OS,default apps and updates.
Now that i have once I have used this usb debigging mode ,
I cannot connect my phone to my laptop even after turning the debugging mode off.
I dunno why the **bleep** this is happeining
thanks bro
