Hi YannisTs,
Are you using any Battery saving app or Memory performance app on the handset? Sometimes these types of apps can cause issues with other parts of a device
Hi Jake, yes I am using Stamina. Other than that nothing that I am aware of.
Thank you uliwooly for this. I did turn on the safe mode and I didn't have any problem with the standard Sony or Google apps.
I think that my carrier's public WiFi app created the problem. I uninstalled it and I will see how it goes.
