I want to buy a Sony Xperia C5 Ultra. I will generally use it outdoors and I want to know the "nits" value of its screen. I could not find it anywhere.
Thank you.
According to GSM Arena (that measure manually the NITS):
Auto-Brightness mode: Up to 335nits,
Manual-Brightness mode: Up to 422nits.
Source: http://www.gsmarena.com/sony_xperia_c5_ultra-review-1310p3.php
Maximum brightness is 400 nits is the information we got after escalating this.
Thanks for your support. I think that value is not good for sunny days. Am I right?
In all honesty I still haven't had issue in sunny days, screen is quite readable. I use the auto-brightness function and when I need more power I switch to manual and go to the max and yeah, it's readable.
