Why do i get whn i open contacts that contacts stopped
My contacts app in sony xperia C4 gets crashed when any contact is been opened. I tried formating the phone but there is no use.
Please give me a solution
Ok thank you. Let me try
Hi @mudassir_khan, sorry to hear about this.
Do I understand correctly that when you try and open up the Contacts application in your phone, the application stops? If that is correct, I would recommend that you start with resetting the Contacts application in your phone.
To do that, go to Settings > Apps > Contacts > Storage > Clear data > OK. This will not delete any of your contacts, it will only reset the data for the Contacts application.
Let me know if that helps!
My Sony Xperia C4 dual model noE5363 after upgrading to a new version marshmallow 6.0, facing a problem contact can't open, showing "unfortunately contact has stop", Sony Authorized service people also can't help. ????
After doing this (Settings > Apps > Contacts > Storage > Clear data > OK), again it shows, Unfortunately, Contacts has stopped. Give me some other solution??
