I have weak signal problem in Sony Xperia c SIM 1. slot. but i solve this problem in my sim 1 slot . Later I found that my cell phone has 2 option 1 is WCDA network and other GSM network . When I select GSM net work only then my problem gone away . I discovered that when disturb in wcdma network by network provider that time it was happnen . Please do that then your network problem will difinitely go . There is no problem on SONY Xperia C . I believed that . Good luck
Hi there,
Perform a software repair using Sony Update Service.
Make sure that your battery is charged at least 60% and if you want to backup your important data, read this topic:
If that fails, I'm afraid you'll have to take it back to a service center for further examination.
Keep us informed.
i went through software repair via sony center only but found no results...
i again visited sony service center and submitted my issue. got a call from there that there is problem with my sony xperia c mother board. they are going to replace a new mother board in my cell and i will get it back in 4 to 5 days.
lets see what happens.
have you tried clear the port and proxy from apn settings?
go to settings >> more... >> mobile networks >> select sim card >> access point names >> choose your active apn >> clear only the port and proxy
Excellent, I´m glad to hear that
Thanks Man, My prolem is solved. Cheers
