As above,do not use the inbuilt option from settings-storage. Do it using file commander with cut/paste.
Go to settings > about phone > which android version and build number do you have? have you encrypted the phone?
whice image file ????
Because I just ran into this problem as well.
The following characters are illegal in file names on SD cards:
Also, a single '.' is legal, but multiple '.' characters are illegal.
They're not illegal on the internal storage.
It'd be nice if the transfter software checked the filename and handled it gracefully. I recommend avoiding file names containing anything but a to z 0 to 9 and underscore _ or minus -.
