I am finding problem in updating my xperia device although i had gone through all the option that are available on website and the sony softwares. Sony companion is just a hopless software. Not working at all and after some time it stops. Please make a provision so that the system can be updated directly over Wi-fi like samsung. Thank you
Have you tried sony update service?What problems do you encounter?
It is switching from one end to the other and showing connecting to server. It is not showing any message but also not able to connect to a server.
In Pc companion or SUS?
In sony update service.
What windows are you using?Try on another computer.
It could be something with the sony servers.Have you tried another computer?
Great.
