You can't overcharge your battery - As soon as the charge reaches 100% it will stop charging and then start discharging then when it gets to a pre-defined level it will then start to recharge back to 100%
@Alexey600 why would you want to use a battery app which will only use more battery - Defeats the purpose of stamina mode
Remove it as it's not needed
