- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
June 2015
June 2015
Hello I get a new Sony xperia c3 and I have enabled battery stamina mode but can I use du battery saver from Google play with stamina mode or it will damage my battery? I have used 2 programs at the same time for 2 days...Thanks all answers will be appreciated!!!
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
You can't overcharge your battery - As soon as the charge reaches 100% it will stop charging and then start discharging then when it gets to a pre-defined level it will then start to recharge back to 100%
5 REPLIES 5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
@Alexey600 why would you want to use a battery app which will only use more battery - Defeats the purpose of stamina mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
Thank you for reply sir but there is a function in du battery saver it can make a healthy charge to protect your battery from overcharging does stamina mode do the same thing as du battery saver? And do you recommend using the two programs at the same time?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
Okey what to do now keep Du battery saver working with stamina mode or it will cause conflict with stamina mode?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
Remove it as it's not needed
