Perhaps a new SIM card could solve this issue, although it could be network related. Settings > about phone > status > signal strength, what do you see?
Signal Strength
| -67 dBm | Minimum signal strength for applications that require very reliable, timely packet delivery. |
| -70 dBm | Minimum signal strength for reliable packet delivery. |
| -80 dBm | Minimum signal strength for basic connectivity. Packet delivery may be unreliable. |
Seems to be a network coverage issue.
Network works then suddenly disappears for hours. am using a dual c4 HOW do I fix it?
Exactly the same problem!!!
I need a solution ASAAAAAP!
Restarting or removing SIM cards then inserting them used to work few days ago. But now nothing works!
I CAN NOT RESET MY DEVICE. RESTING NOW WILL MAKE ME LOSE ALL MY INFO AND ONLINE ACCOUNTS WITHOUT WHICH MY PHONE IS WORTHLESS!
Same problem ... My signal strength is 0
((I didn't change my location and my brothers phone can connect))
Is it software or hardware issue?
Same problem with my C4. Network is Zero. And it will comeback after sometime. It works intermittently. It was fine until a year.
Re: Sony Xperia C4 Dual - Network Problem
same with my device , sony c4 dual e5333 , no signal , i check the imei , baseband , but still no signal , when i try *#*#7378423#*#* , locked remote state = locked , does that have an effect ?
