I got today the update for 5.1 on my phone,it was charged 55% and after downloading,i pressed install...for some reason the software update failed and now i can't boot the phone,appearing an ''error'' message with the andoid icon at the top,what can I do?I bought the phone last month
Done the repairing. Everything works fine now, but I lost all my contacts and my stuff. That's the problem.
Same problem as others. My phone got stuck with an error droid logo when update to 5.1.
That's bad I'm currently trying to do a software repair and getting ready for the long process of reconfiguring everything again!...
Bad, bad, bad....
C.
Alright. I finally repaired my device with PC companion.
I'm now back to lolipop 5.0 with a blank device and some configuring ahead, bye bye pictures!..
C.
You can repair the phones software by downloading and installing Bridge for Mac in your Mac. You can find a step by step instruction on how to repair the phones software using Bridge for Mac here: http://talk.sonymobile.com/t5/FAQ/How-to-perform-a-software-repair/m-p/1061296#M25.
I'm afraid the software repair will delete all data in your phone but when the phone doesn't start, i'm afraid there's no way to access the data in it.
Finally manage to repair...This is too bad Sony.....Lost some of the contacts....But back to 5.0 and not 5.1...Whay is that @Rickard?
Hey,
How do i get past step 10? the prepare stage. i cant press the power button and volume button at the same time, it doesnt do anything if the cable is in the pc. i pressed the ''i need help, the instruction doesnt work'' button, but there isnt any help there either.
please help.
Nowadays, it is Xperia companion that does the job.
Fast and easy !
My phone is up and running again !
Hi @Mahmoudhsn, sorry to hear that.
Are you still able to use your device? If yes then you can try clearing data for the Software Update app then search for updates and try to update again. You can clear data for this in Settings > Apps > [menu] > Show system > Software Update > Storage > Clear data.
If you have access to a PC you can also update by using Xperia Companion. You just need to connect your device and Xperia Companion should automatically search for any new available updates.
I hope this helps, feel free to let me know.
