screen dims and brightens automatically
Phone雲
Besucher
My xperia C3 has below problem and can't solve by Customer Service:
When web page, forum, letters that contains high colour(red / yellow words , pictures) the screen dim automatically. When scroll it out of the screen, it becomes bright again. It hurts my eyes and annoy me so much.
CS said it can't be solved, please wait for version update, maybe.........
Can I only wait, wait and wait? Xperia C3 is **bleep**.
- auto detect envoirmental function is off
- no screen saver
- no 3rd party software installed, just rec'd from CS
- android 4.4.2, software version 19.2.A.0391
25 ANTWORTEN 25
ravi_p7
Besucher
@hellohelloworld : Hi..its almost solved..thanks a lot. Since i bought this mobile, I hav been looking forward a solution for this, but still i found on very few pages getting dim n bright, should increase to 63 to any other figure?
hellohelloworld
Besucher
I refer to this dim and bright problem. I suppose Sony would fix it on lollipop update, but it is not. Recently, I've tried to adjust the white balance setting, I found that some setting can improve the problem a lot, such as (63,63,63).
I should not say this setting can totally solved the problem. What we should do now is sharing the webpages that got dim and bright, and then figure out the best setting together. I am just a simple user, but I spend a lot of time trying to make my c3 better.
I hope this problem can be solved. Please share anything that we can improve our C3 such as the front camera. Before Sony releasing another update, it is one of the thing we can do in this forum.
Thanks!
ravi_p7
Besucher
Hi..after a visit of many web pages n playstore i figure out 117-117-117 is d best count to remove almost 99.9% dim n bright. U can also check in playstore at editor choice..scroll down may b 2nd app called EQ being with skyblue.
ravi_p7
Besucher
Hi..after a lollipop update issue with front camera i hav tried many camera apps n found finally " A better camera" app [ Avbl in play store] this app works fine in c3 dual. 4:3 size pics good in this, once u choose 16:9 again d pics r dark. For this size better take it n sony camera by changing setting to manul n hdr on..somehow better alternative until d new update release from Sony.
hellohelloworld
Besucher
Thanks! I am happy to hear your suggestion. How about the flash light of front cam? If it works,I will update to lollipop again. At this moment,I keep using the Kikat build .391 firmware. It takes time to upgrade and downgrade again.
ravi_p7
Besucher
Ya.. Flash is working fine with this app. But b4 u update install this app in kitkat n check it, if u convince, go ahead..
hellohelloworld
Besucher
Hello, I have tried "a better camer" and "camera fv-5" on lollipop, both work fine on front cam 4:3 including the flash light. As you said,16:9 got dark image. Thanks for your clear explaination. I think it is the best temporary solution for c3 lollipop user at this moment.
ravi_p7
Besucher
Camera fv 5 seems to b no front cam? While im using with kitkat i used camera fv 5 and cinema fv5[ video rec] both apps fulfilled my requirement.
hellohelloworld
Besucher
The new version of fv 5 has front cam.
ravi_p7
Besucher
No, i did nt find front cam option, wer its exactly located? Im using camera fv 5 lite version. It seems only purchased version had this feature?
