It's not possible to remove the camera shortcut from the lock screen as standard in your Xperia C. However, you can use some 3rd party apps like 'lock screen policy' that you can find on Google Play to remove the shortcut from the lock screen.
Try going into the camera settings and find quck launch and turn it off. As this has worked for me.
thanks Dude its works for my cellphone(sp)
thanks quck launch settings work for me xperia z kitkat
This also works in Xperia ZL. thanks buddy
