screen would not dispay after call is dialled. Re installed phone software, tested it with sony diagnotics, worked in 1 out of 4 or 5 instances I ran the test.
Any solutions?
Now the phone works great.
friends kindly try this out, remove the back filp cover and then try little bit loosing the screw back to the Sensor... thats it the phone works great.
Thanks
Hi all,
I faced the same Proximity Sensor problem too! It definitely the Sony Xperia C hardware issue!
Today I managed to find out a little "solution" here:
Whenever your screen goes black during call.....try to press the "Sony" word/icon on the top of the phone, then the screen eventually will come back.
Please give a try...
Good luck.
So many people are facing this comman problem. Can anybody relase any software update to solve this issue or any other solution to fix this issue.
Thanks.
Thanks.
Thanks.
Thanks.
Hi
I faced the same issue along with few other issues they got the mother board replaced and they screwed the front camera which i just noticed. (the camera isn't placed properly and the clarity is like 0.00001 pixels.)
As I filed A Complaint Aginst them And Sent A court Notice To Them.
They Called Me yesterday And Are Saying that We have Got A New Phone for You and Said Kindly Come And Take it.
I refused that because i want a compensation for the earlier harrasment and wastage of my time.
If Anyone Needs Any Help against them Kindly contact me on my email [email protected]
