screen would not dispay after call is dialled. Re installed phone software, tested it with sony diagnotics, worked in 1 out of 4 or 5 instances I ran the test.
Any solutions?
Is there anything near or on the proximity sensor? protective case, or protective film or even grim?
You can test it
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
It might be a hardware issue. you could repair your phone with SUS or PCC but if that doesn't work then
http://www.sonymobile.com/global-en/support/contact-us/
Bridge (for Mac)
Alternatives on How to backup Xperias
I brought xperia C 2 days ago and facing same issue.. Can anybody help us please
@sanjeet
You don't have to create multiple threads, one is more than enough
Looks like a hardware issue to me as well. I had taken it to the service center who formats, reinstalls the os & gives it back. Works for few calls & then is back to normal. The company is not yet ready to accept the issue as a hardware one.
Only option I see today is to use a flipcase all the time & making sure that not even a fingerprint comes nearr the sensor. This is an un relasitic solution for a phone in this premium segment.
Dear All,
I don't know whether this solved the problem or not, But even I am facing the same problem. I bought the phone last week and also put a scratch a guard on it.
When I am dialing a phone and put it on MY ear display automatically turns off but when I want to end the call it never turns on nor power button works.
Kindly advise whether I should remove this scratch guard to fix this issue or not or is their any other solution for this. I am having 30 days replacement gurantee with the online portal from where I bought this.
Thanks In Advance.
i bought xperia C 2 day ago...its proximity sensor is not working.....as soon as i make a call its screen goes off but dont restores to normal state even phone is not near to ears......is it hardware problem or any settings issue?
