we are all facing the same problem,,SONY doesn't giveus SOLUTION!!!!
SONY SHOULD RELPLACE OUR PHONE THAT'S THE BETTER SOLUTION...THERE IS A DEFECT TO THEIR PRODUCT AND YET THEY ARE NOT DOING ANYTHING..
I SHOULD HAVE BOUGHT IPHONE OR SAMSUNG INSTEAD!!!!
How do I save apps to my SD card to free up space
Until now, Sony has never respone to the existing customers & users to the problem.
Perhaps the best solution for all sony users are to boycott sony forever. start publish all the problems & customers good respone culture to public.
Hi Friends...It seems SONY has left us with no option to solve the Low memory problem, but there are certain tips which can help:
1. Install APP2SD app and move all possible apps & games to SD card like the ASPHALT8..
2. Set the default storage to SD card in the settings and as well as camera settings. Restart the phone so that the changes are saved, to confirm the same once phone restarts, you will find notification confirming on the change in default storage location.
3.Disable all the preloaded Apps like Google Plus, Line,Evernote, etc which are not used, these apps take frequent updates and eat up the memory space. Disabling helps prevent this apps to take updates.
4.Install app like 360 secure which will help free up memory and RAM frequently improving the performance.
Hope this works out to some extent, although its not a permanent solution...
what should i do to get out to this problem
