Go to settings> apps- you can uninstall all apps that you see there. To free more space on phone memory install app manager III (app2sd) and move your apps to sd card, thus u will get enough free memory.
For me also having the same problem only 50 MB is free space. i cant install any apps i have installed AppmgrIII, Clean master
sony pre loaded store in device memory google chorme, google search, google+, office suite, Line i can't move these apps to sd card if i uninstall above apps it re-install when i goto Play Store. what shall i do? any idea guys...
First uninstall all those heavy apps., then reinstall them from play store, now you can move them to external memory. If u root your phone u can remove many apps from phone memory and later reinstall on sd card if required.
go to setting -->storage and change the preferred install location to sd card. Make sure you have inserted the sd card, if not, it wont change.
Hi there,
Unfortunately there is no solution!
Simply, With Jelly Bean You can't move app to sd card.
Apps such as App2SD require rooted phone, but then You are losing your warranty.
Search the forum and you'll find a lot of topics related on your inquiry.
Cheers.
hehe ok then thnks you , my device memory is quite full then -.-
