The phone only charges when it is turned off. It does not charge the battery when it is turned on.
I have tried different chargers
I have restored it from the factory, I deleted all the content but I have not been able to solve the problem.
Let me see if you can help me, thank you.
Thank you very much for your answer,
I used Xperia Companion to repair it but I have not been able to solve the problem, I do not know what else I can do, thank you.
Thanks @YoGem for your answers, every time you tell me something new you give me hope
I just do what you tell me to remove the cards but I can not load the phone while it is on.
@Ahandion After all this testing, I have just one more question for you... you may have to do this last test for me:
1) Wait the phone to turn off because the battery level goes to 0%;
2) Do not turn on the phone but instead put it in charge and note the time when you put it to charge;
3) Please note when the phone finish to charge.
Let me know how long it take for it to charge the battery when it's off.
@Ahandion yep, I don't think that's quite right... You said you tried with different chargers, but did you try also with different cables? Before asking you to contact Sony, I want to rule out the possibility of a faulty cable. Ask a friend to borrow you whatever charger they have, as long as it's regulat and not USB C it will work with your phone. Cables can be a real problem at times.
@Ahandion at this point I can just think about an issue with the board, especially with the charging circuit or the battery itself, you will have to contact Local support.
I really wished I would not tell you that but sorry, that's an hardware issue
