HI
My flashlight icon disappears and appears by it self from the active quick settings bar although I did added it and never removed the list
Uliwooly the same i kean but with 4G is gone after update
@Unregistered user
Not the same situation, @samaa can see the icon but it's gone after a while.
Uliwooly, i mean situation that icon gone from the same place 😉 Thanks, other solved problem. I though just i can't see this icon, but looks like this is Sony missed in software this icon or special did not 😉
The flashlight icon appeared it last for 1 day and disappeared again
This alart pop up
