My memory card is getting removed unexpectedly,after I have updated my device Xperia C5 from Lollipop to Marshmallow. I have restarted the mobile and then while I'm listening to music or using the apps,i'm getting a notification that memory card removed unexpectedly unmount it to avoid data loss. Can anyone help me to solve this.
That seems to be a faulty SD card, reformat the SD card and report back.
Hi @sd_card_issues,
I'm sorry to hear about this.
To make sure that there is nothing wrong with your phone I would recommend following recommendation by @uliwooly.
If you have another SD card or if you can borrow one from a friend, colleague or family member, you can mount that in your phone and see if you experience the same behaviour that the SD card gets removed unexpectedly.
Let us know how it went!
Hi @Shaggyd,
I'm sorry to hear about that.
Are you doing anything specific in the phone when this happens? For example, using apps that are transferred to your SD card or listening to music that is on the SD card?
If you haven't formatted the card, I would recommend starting with that or if you have another SD card that you can mount in the phone and see if you experience the same behaviour, that the SD card gets unmounted.
Let me know how it goes!
Thanks for the update!
Is this something that you started to experience directly after the update to Marshmallow, or was it working correctly for a while?
Can you try rebooting your phone in safe mode and see if your SD card gets unmounted when third party applications aren't loaded?
Let me know if there is any change in safe mode.
