i cant unlock the screen using the numeric password that i set in. im pretty sure that im using the correct password, ive tried many times, but its not working, shows incorrect. would appreciate some help. thanks.
if you can't remember it or for some reason it doesn't work, check this guide
if that doesn't work then you will have to factory reset the phone
Bridge (for Mac)
Bridge (for Mac)
thank you so much, you've been a great help! :smileyhappy ^_^
my battery has low , and cause my phone shutting down. i'm charge it , and i'm turn it on.
after that , i want to open my lockscreen . when i put my passcode , it was incorrect.
what should i do ?
