In Xperia C How We Can Set Different Ring Tone For Different Contract From File. Which Mean How To get The Songs From File To Set It Up In Contracts .As While Setting up The ringtone in Contract I don’t Find The Option to Select File form Album or File Folder where I Have My Songs File . Kindly Help L:smileyconfused::smileysad:
Iam Able Attach Pictures To Contact But Not Able To Get The Option To Slect Ringtone Or MP3 From My SD Card
Contact a staff member for further help:
http://talk.sonymobile.com/t5/Welcome/Community-users/m-p/634967
I Hve Sent John A Message Reguard This & I have Recently Updated The Software Too From Sony Service Center
So This Is Not Going To Be Fixed Right
I do not know,I don't think I have seen this before.Last thing you could try is clear defaults for sound picker,but if you say you have tried a software repair and did not help,I do not know.
I Have Clear The Clear Cach & Done Force Stop Too For Sound Picker & But Still Iam Not Getting This Option & I was Thinking That If I Disable The Sound Picker & Re Enable If Do You Think It Will Work
There is no need,I don't think it would help.Lets wait until you get some answers from the staff guys.
I Have Send Him Messages But Till Now I Have Not Got Any Reply
Try Samuel.
I think you may have assigned any of the ringtone related applications as default. Try clearing default settings for sound picker or if you have assigned any other application to handle ringtone selection.
As @alexdon mentioned, using sound picker you should be able to see a note in the top right corner when selecting ringtone. That note will bring you to the Walkman library and you can choose from any of your songs.
If you can't find the application that you have assigned as default for this action I think you may have to reset the phone.
Yup You Are Right As I was Instructed I Did That & as Well As I Have Updated The Software Too But Still Iam Not getting That Option To add Ringtone In Contract .....
