In Xperia C How We Can Set Different Ring Tone For Different Contract From File. Which Mean How To get The Songs From File To Set It Up In Contracts .As While Setting up The ringtone in Contract I don’t Find The Option to Select File form Album or File Folder where I Have My Songs File . Kindly Help L:smileyconfused::smileysad:
I have suggested clear defaults for sound picker,it seems you use something else.But anyway,good you got it.
Select your contact-tap on it-tap the little pencil in the right corner-down there should be an option ringtone.
Yup I get The Option for The Ring Ronte Which is Default Ring Tone But I want To Select Ring Tone From My Files But I Dont Get This Option in Xperia C:smileyconfused:
I think the contacts must be saved on your internal memory and not on the SIM.
All Contract Are Save in Phone Book Memory Or in Xperia Word Its In Local Contracts ...:smileysmileywink:
I do not think you understood me,can you post a picture of a contact being edited?I have seen this thing before and it was becuse the user was editing on the SIM.
Yup You may be right but iam no so foolish that i i wiil keep my contracts in sim card & even I Know That In sim Card I will nOt get Any Option to add any additional feature in contacs . As All Contracts are in Mobile Internal Memory & Or In Xperia Word Its Says Local Contracs & As im Able Add Pic in Contracts As well as i m able to add ringtone which is default ringtone of mobile phone but i m not able to set my one ringtone from file as im not getting that option to add ringtone from file while adding the ringtone...:smileysad:
Strange,have you selected an option as always through the sound picker?Try settings-apps-all-sound picker,clear default.
I Have Tried Both Way By Moving Contract To Sim Card & As Well As By Moving The Contract To Phone Memory :(:smileysad:
I Have Tried With Sound Picker Too , For example I went to contract & Than I went On Edit Option I Slected ADD RINGTONE Now i get All The Default Ringtone Name List & But I Dont The Option to Select The Ringtone From My File ...:(:(
