- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have problem regarding my xperia c.. I have uninstalled most of the apps that I downloaded but it still shows storage is full.. I cant download anything because storage is full eventhough I had nearly uninstall all the apps.. ..What should I do?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try settings-apps-all-media storage.Force stop and clear data.Restart your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you go to settings-apps-all,select some apps and move them to internal storage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have done that to all my apps.. The storage still full..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have all my apps in SD card but still when any updates come for pre installed apps it's saying running out of memory.
as you said I tried to move some internal apps to sd card or internal storage but it's not showing any option.
in 20K range xperia C is a flop model.
Is there any permanent solution?
or else am thinking to change my handset.
Thanks
Raghu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That is not ok,it seems that C is the only Xperia that can move apps to SD.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have moved all apps that I can from my internal to my sd card and still i cant download any apps larger than 10mb and i have only 87mb on my internal, i have more than 14gb open on my sd card and my phone is set to install on my sd card, it still doesnt work, i have resently set my phone back to factory default but i can still not download big apps. How can i get my phone to install only on my sd card so that i can actually get apps on my phone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
