How to set default calling sim in Sony Xperia C4 as we need to select a sim always while making a call. If there is any app in play store that may please be shared. My twitter handle /dnegi1
As far as i know,you can't set a default sim for calling.
But what i do know is that when you dial a number,at the bottom of the dialler has two green keys where you can tap to choose either sim card used for calling.
When you have only one sim card,then only one green bar would appear.
In other case,if you want to use only one sim card,then you could do so by going to Settings > Dual Sim Settings > Choose one of the sim card.
Hope that helps!
Hope that helps!
Hi @Sunny_Singh,
As Ashroft98 says there is no setting for this and I am personally not aware of any app that let's you do this.
I have a sony C4 dual sim Phone and has the following issue since the begining, :
1. The Sony UI does not give option to select a default SIM for calling. every time i have to select which SIM to call which is very painfull, I went to service center and they refused that this does not have this feature. However, cheal phones from Lenovo, Xiaomi in my home have this basic feature. I want sony to makes minor changes in thier UI to make this happen ASAP.
2. Do not get lockscreen notifications with lollipop.
