That is normal,I do not think the default app lets you see the numbers at the same time.But after you make calls,you can see in recent call log with numbers.
I'm not really sure what you mean. Could you please elaborate a bit?
Its not possible to view the numbers that way in the default phone book application.
But check on Google Play store, there might be a contact application that supports this that you can download.
Anytime.
