@samaa It has been pretty much covered, if safe mode doesn't help, I think a software repair might.
Hi samaa,
Are you trying to add a new lock type? Do you also have an exchange work account loaded on to your handset?
yes iam trying to add new lock
and no i don't have any work account
Ok this may be a Administrator situation.
Can you go to Security and then access Device administrators and let me know what you have listed?
android device manger
Protection by my Xperia
Configuration agent
All on
Can you try unticking the configuration agent and see if you can clear the content
I did and it Still gray
Since removing the account from the device have you restarted the handset?
Strange, one of the device admins is not allowing the change to take place, it is possible that it could be the Android Device management or the My Xperia. You could try unticking both to see if the issue remains.
