Why do you need 20 alarms - would it not be easier to set reminders if that's why you need so many
You probably need to use a 3rd party app for this
what is the use of alarm app if i have to use 3rd party application for such a small requirement.
Its just the bug in the app. sony should correct the bug or give the proper justification.
You are the 1st person to complain about this in the all the years of this forum been active - i highly doubt this is an issue that needs to be fixed just for you
Are you even official sony support person?
It is not how many complaints you are getting, It is what complain you are getting and
whether it is genuine or not.
I'm not Sony but what I'm saying is millions of devices sold and after years of this forum been up and running you are the 1st and as said I doubt that this will be considered an issue which needs to be fixed
You can set an alarm to repeat on some days at a specific hour,but not several times/day.You need to set it again.
It is indeed something I have never heard of,more than 20 alarms.
I also have this issue. Before android i always had ios and am used to setting alarms to basicly plan out my intire morning. this takes up about 15 alarms togather with other alarms i use to remind myself. I just cant find a reason not to change this, it seems like an easy fix.
