Решено! Перейти к решению.
@jart_aziz wrote:
Is it the setting button on the upper left side of the app..?
Hi there,
Yes it is.
Try the following:
Dial *#*#7378423#*#*>Service Tests>test your camera with camera key.
Also,
Settings>Apps>All>Camera> Clear Data/Cache> Force Stop+Restar your phone and then try again.
Hi there,
Try to press and hold the camera button until you hear 2 sounds(clicks)?
Also, do you have: Camera App>Capturing Method( or something like that)>Camera Key Only.
Cheers.
@jart_aziz wrote:
I try to hold the camera button.. I heard the 2clicks sound but no pic snapped.. I use camera that come with xperia c.. No other camera app..
Camera App(main)>Settings>Capturing Method( or something like that)>Camera Key Only.
Hi there,
Yes it is.
Try the following:
Also,
....If you're still unable to use camera button, repair your software using Sony Update Service
Cheers.
Hi there,
You are definitely have to back up your phone, because your data from internal storage will be deleted during the repair process.
Cheers.
