i have 2 xperia c. 1 with red led when charging and the other 1 has no sign at all.
both have tried with power button + vol down still no respond.
the red led have been succesfully repaired with xperia conpanion once. but when to blank after fews day. for now, after more than 20 times trying with XC, emma and flasher by androxyde all come with the same result. NOTHING
also i have tried
restart my laptop
using other usb ports
charge the font halfday
the led led will also turn red when i plug into usb. the other one no sign at all
10/038/2017 09:38:37 - INFO - Flashtool Version 0.9.23.1 built on 11-01-2017 15:12:00 10/038/2017 09:38:37 - INFO - Executing search strategies to find proxy selector 10/038/2017 09:38:38 - INFO - No proxy found for IE. Trying next one 10/038/2017 09:38:38 - INFO - Strategy firefox failed trying next one : No Firefox installation found 10/038/2017 09:38:38 - INFO - No proxy found for java. Trying next one 10/038/2017 09:38:39 - INFO - Syncing devices from github 10/038/2017 09:38:39 - INFO - Opening devices repository. 10/038/2017 09:38:39 - INFO - Scanning devices folder for changes. 10/038/2017 09:38:49 - INFO - Pulling changes from github. 10/038/2017 09:38:51 - INFO - Quietly closing devices repository. 10/038/2017 09:38:51 - INFO - Devices sync finished. 10/038/2017 09:38:51 - INFO - Loading devices database 10/038/2017 09:38:51 - INFO - Loaded 94 devices 10/038/2017 09:38:51 - INFO - Starting phone detection 10/038/2017 09:38:57 - ERROR - Drivers need to be installed for connected device. 10/038/2017 09:38:57 - ERROR - You can find them in the drivers folder of Flashtool. 10/039/2017 09:39:17 - INFO - Device disconnected 10/039/2017 09:39:20 - ERROR - Drivers need to be installed for connected device. 10/039/2017 09:39:20 - ERROR - You can find them in the drivers folder of Flashtool. 10/039/2017 09:39:26 - INFO - Device Status: NOT FOUND 10/039/2017 09:39:35 - INFO - Now plug your device in Fastboot Mode 10/039/2017 09:39:49 - INFO - Device disconnected 10/039/2017 09:39:56 - ERROR - Drivers need to be installed for connected device. 10/039/2017 09:39:56 - ERROR - You can find them in the drivers folder of Flashtool. 10/040/2017 09:40:14 - INFO - Filed 10/040/2017 09:40:17 - INFO - Now plug your device in Fastboot Mode 10/040/2017 09:40:18 - INFO - failed 10/040/2017 09:40:20 - INFO - Device disconnected 10/040/2017 09:40:23 - ERROR - Drivers need to be installed for connected device. 10/040/2017 09:40:23 - ERROR - You can find them in the drivers folder of Flashtool. 10/040/2017 09:40:24 - INFO - Now plug your device in Fastboot Mode 10/040/2017 09:40:26 - INFO - Failed 10/040/2017 09:40:27 - INFO - Now plug your device in Fastboot Mode 10/040/2017 09:40:28 - INFO - Failed 10/040/2017 09:40:28 - INFO - Now plug your device in Fastboot Mode 10/040/2017 09:40:30 - INFO - Failed 10/040/2017 09:40:34 - INFO - Device disconnected 10/040/2017 09:40:40 - ERROR - Drivers need to be installed for connected device. 10/040/2017 09:40:40 - ERROR - You can find them in the drivers folder of Flashtool. 10/040/2017 09:40:43 - INFO - Device Status: NOT FOUND 10/040/2017 09:40:52 - INFO - Device disconnected 10/040/2017 09:40:55 - ERROR - Drivers need to be installed for connected device. 10/040/2017 09:40:55 - ERROR - You can find them in the drivers folder of Flashtool. 10/041/2017 09:41:23 - INFO - Device disconnected 10/041/2017 09:41:26 - ERROR - Drivers need to be installed for connected device. 10/041/2017 09:41:26 - ERROR - You can find them in the drivers folder of Flashtool. 10/041/2017 09:41:55 - INFO - Device disconnected 10/041/2017 09:41:58 - ERROR - Drivers need to be installed for connected device. 10/041/2017 09:41:58 - ERROR - You can find them in the drivers folder of Flashtool. 10/042/2017 09:42:26 - INFO - Device disconnected 10/042/2017 09:42:29 - ERROR - Drivers need to be installed for connected device. 10/042/2017 09:42:30 - ERROR - You can find them in the drivers folder of Flashtool.
should i just throw it away?
